Joined: 21/12/2018(UTC) Posts: 85 Location: SA Thanks: 22 times Was thanked: 9 time(s) in 9 post(s)
I have a HQ driver side front door with chrome trim around the window. I assume it came off a Statesman or similar. I would like to remove the trim to repaint the door but can't see how it is attached. Anyone know? TIA.
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
From memory they just clip on. You have to use a couple of wide flat edges to unclip them, like a couple of wide chisels. Its been 30+ years since I touched one though, all the good doors around back then were off Statesmans. |
