robone Offline
#1 Posted : Wednesday, 8 September 2010 8:28:30 PM(UTC)
robone
would this be a engine no
gpa 21002 mybe from a vl,vk
#2 Posted : Thursday, 9 September 2010 1:18:14 AM(UTC)
Could you rephrase the question please.
#3 Posted : Thursday, 9 September 2010 5:16:32 AM(UTC)
If you're asking if the number GPA21002 is a VK/VL Group a engine number, then the answer is no.
The engine number will be 2 letters (with V as the first one), followed by 6 numbers.
robone Offline
#4 Posted : Thursday, 9 September 2010 5:37:19 AM(UTC)
robone
thanks for that mick
on the drivers side of eng is A9L97121002002.88 whith lots of dots
in between and 21002 is on the head's as well, i was given these no
over the phone
he said the eng was out of a VL group A looks like no eng no and the car was written off so he,s trying to find out what the nunbers meen
i know a bit about xu1,s but this is new to me
vin
#5 Posted : Thursday, 9 September 2010 6:26:27 AM(UTC)
Is that stamped into the RH pad, or cast?
My guess on the 21002 is serial numbers from an engine reconditioner, as their are no serial identifiers put on heads (only a casting date).
robone Offline
#6 Posted : Thursday, 9 September 2010 7:11:32 AM(UTC)
robone
he said the long numbers are stamped on driver side of engine and
gpa21002 on other side eng i asked him is there any casting date,s
on the eng he is going to have a better look at eng
cheers vin
