would this be a engine no gpa 21002 mybe from a vl,vk
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Could you rephrase the question please.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
If you're asking if the number GPA21002 is a VK/VL Group a engine number, then the answer is no.
The engine number will be 2 letters (with V as the first one), followed by 6 numbers.
thanks for that mick on the drivers side of eng is A9L97121002002.88 whith lots of dots in between and 21002 is on the head's as well, i was given these no over the phone he said the eng was out of a VL group A looks like no eng no and the car was written off so he,s trying to find out what the nunbers meen i know a bit about xu1,s but this is new to me vin
Is that stamped into the RH pad, or cast?
My guess on the 21002 is serial numbers from an engine reconditioner, as their are no serial identifiers put on heads (only a casting date).
he said the long numbers are stamped on driver side of engine and gpa21002 on other side eng i asked him is there any casting date,s on the eng he is going to have a better look at eng cheers vin
