Fastlane
Holden Forums
Holden Technical Talk
Yella Terra iron head spark plugs
NGK BP5FS spark plugs that fit the standard Holden 202 red motor head do not fit the yella terra head. Can anyone tell me the plugs that do fit a yella terra iron head?
Most Yella Terra heads are just Holden heads that have been reworked, so standard spark plugs will fit, but there are several different heads.
EH-HG heads use BP5ES HQ-HZ heads use BP5FS WB/VC to VK heads use BP6EFS-13
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
Many thanks for that. Now I can get on with the real job of fixing all the tin worm in the body of the car.
Fastlane
Holden Forums
