Hi, Have just got my HQ GTS/4 sprayed in original factory color with black stripes, have used the factory diagram for guide with 35mm at cowl into 50mm on front nose, but they look off. Looked at other around but cant confirm any advise??? Cheers GM05HQ
Hi Mate,looks to me like the middle gap is too big?P.S..nice facebook use,thats about all its good for...lol http://cgi.ebay.com.au/H...230b4e7c30#ht_500wt_1156Jim in Adelaide.. |
Jim in Adelaide.. |
Joined: 29/07/2006(UTC) Posts: 763 Location: in the shed
Thanks: 8 times Was thanked: 14 time(s) in 13 post(s)
Well thats a little heart breaking isnt it!?! The main problem is the black should all be on the high part of the bonnet, it shouldnt be rolling off the edge and down to the lower section at all, not even the thin lines.
I found these instructions not sure how correct they are:
Measurements in mm , the gap in the middle is 43 so go 21.5 either side of the centre, then 12 mm stripe then 6 mm gap then wide stripe across.
From the outsides start on the raised center section following the body pressing ,starting as soon you get to the flat part .Again 12 mm stripe 6 mm gap.
Boot start 25mm up from the bottom , outside radius on the corners are 80 mm.
Nosecone start 50 mm up from grille opening, outside radius on the corners are 80 mm
Don't forget the 12 mm stripe cross over at the back of the bonnet
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin)
"I would never want to be a member of a group whose symbol was a guy nailed to two pieces of wood" (George Carlin) |
Yeah cheers mate got it and also managed to find a stencil with what i believe are the right specs and the numbers you listed.
They are gonna get re-done this week.
Will post some more once are correct.
GM05HQ
