Squeak327 Offline
#1 Posted : Saturday, 5 March 2011 4:39:42 AM(UTC)
Squeak327
I'm in the process of final assembly of my car and need to put the LSD warning sticker on the door pillar.
Can anyone tell me definitively which way it should go. That is to say should it be applied with the word "CAUTION...." at the bottom left so you would read the sticker, if sitting in the driver's seat with the door open, up the pillar
OR
should the word "CAUTION..." be at the top right so you would read the sticker down the pillar.
I have seen them both ways at shows. Mine is a Sydney built HK if that makes any difference.
#2 Posted : Saturday, 5 March 2011 8:26:37 AM(UTC)
Hi there
These are photos of HGs - hope this helps.
Squeak327 Offline
#3 Posted : Monday, 7 March 2011 10:03:24 PM(UTC)
Squeak327
Thanks Jeremy.
I found a car on AMCS claimed to be unrestored which has its door pillar sticker oriented the same way as your photo too so I have placed mine that way also.
Des
#4 Posted : Monday, 7 March 2011 10:06:47 PM(UTC)
No problem
Did you get the boot one sorted as well??
CrustyHK Offline
#5 Posted : Tuesday, 8 March 2011 6:25:14 AM(UTC)
CrustyHK
There's an interesting point. Did the HKs have them in the boot? The HT & G certainly did. My HK doesn't
bazza30555 Offline
#6 Posted : Tuesday, 8 March 2011 12:05:24 PM(UTC)
bazza30555
Melbourne HK . CAUTION at the top right on door pillar, Boot
Sticker mounted lower down than the 1 shown and on the flat area to the left above the 3rd large hole pictured. Car is unrestored.
