#1 Posted : Sunday, 13 March 2011 8:33:35 AM(UTC)
How does the headlight switch on the VR come off?
thanks
#2 Posted : Sunday, 13 March 2011 8:40:32 PM(UTC)
You need to remove the whole cluster surround (ie the entire black plastic bit that goes all the way past the A/C vents - it's only a couple of screws above the cluster & the rest are all push-in clips).
Once it's out, you rotate the retainer on the rear of the headlight switch to release it, and it drops out of the surround.
These rarely give trouble - if at all. I've never known anyone who needed to replace it. More likely culprits for faults are the headlight relays in the underbonnet fuse box, and the BCM - which controls the auto lights-off function (if you leave them on, it cuts power to them when you open the drivers door).
#3 Posted : Monday, 14 March 2011 12:13:46 PM(UTC)
Thanks Mick.
Yes I have the dash panel out.
the switch is ok, but it rotates in the mount which makes it hard to turn the lights on.
I just want to tighten it.
