maccaz69 Offline
#1 Posted : Friday, 13 May 2011 7:31:55 AM(UTC)
maccaz69
Hi guys I have a vk and it has a steering/suspension problem in that at high speed when I get to a bend I turn the steering wheel a bit and it slingshot steers around the corner!! Tiny corners are ok as are bigger bends when going slowly but on the freeway at a bend I turn a little bit and it just feels like i've turned the steering wheel heaps more than I have.
I have replaced the rear upper and lower control arms and the panhard rod bushes seem fine. So is there any particular bush in the front that can cause this? They don't appear to be any worn but the cars done a lot of k's now and is old.....??????
madanjor Offline
#2 Posted : Tuesday, 17 May 2011 7:13:49 AM(UTC)
madanjor
Have you checked the tie rods?
This page was generated in 0.129 seconds.
