275monaro Offline
#1 Posted : Friday, 20 May 2011 7:31:35 PM(UTC)
275monaro
here is on for you mechanical gurus i have a vt corsa special vehicle with ls1 auto trans my question for you is when i give it a bootfull and use the auto in manual mode or even if i just put auto into 3rd gear the engine warning light comes on and stays on for duration of the drive car still runs fine doesnt miss a beat once engine is turned of the light goes out and goes back to normal after restart any thoughts would be appreciated
hj styleside Offline
#2 Posted : Friday, 20 May 2011 8:15:33 PM(UTC)
hj styleside
gedday mate have u cheacked the gloab cheers
275monaro Offline
#3 Posted : Saturday, 21 May 2011 12:39:49 AM(UTC)
275monaro
yep globe works fine thanks for that
brent motor Offline
#4 Posted : Saturday, 21 May 2011 9:07:31 AM(UTC)
brent motor
maybe go to any mechanic with a scan tool an that should give u an answer. at a guess though i would be thinking the selector module on side of trans
This page was generated in 0.105 seconds.
