witcheshollow racing team Offline
#1 Posted : Monday, 6 June 2011 2:37:22 AM(UTC)
Gday Guys my dad rodeo is running rough at idle when in drive its a 2.6lt fuel injected auto Im thinking it may be the timing is out, cant find a tag with the amount of degrees to set it at does anyone know what it should be? and any other suggestions as to why it may be running rough? engine idles at 900rpm in netureal as its supposed to. Thanks for your time cheers Barry.
"Such is life"
Dr Ric Offline
#2 Posted : Friday, 10 June 2011 2:41:02 AM(UTC)
Dr Ric
It is unlikely that your timing has altered as there aren't any points fitted in the distributor. Most likely cause will be injectors. Try some injector cleaner
#3 Posted : Friday, 10 June 2011 6:18:39 PM(UTC)
Thanks for that I will get him to run some through it on the way home, found out the timing is 12 degrees BTDC, it was set about 16 !! So reset that there was a small inprovment but still a little rough. Cheers Barry.
"Such is life"
