Almost blue slip time(NSW), so need some seat belt advice.Car is 2tag HT monaro. Do I need rear seat belts? The holes are there but are they required for rego in NSW.Also do interia reel seatbelts fit in the front of monaros or do they foul the base of the rear seat.Any advise would be appreciated thanks.
If its a 2 Tag 1969 car it only Needs Front Belts . But some roadworthy places in my experience will make you put rear belts in old car pre 1971 if they see dirty big holes in the parcel shelf where previously some one has fitted belts , in that case they will make you put them in as it has already had them . But technically on the ADR Specs of the Day only Front belts are needed .
