G'day all.
I'm trying to hunt down an image of how/where the brace from the power steering pump to the engine mount, mounts.
Can anyone help me out, please?
Car is a HQ Ute. Red 202.
Grabbed this one off eBay and it arrived today, but have no idea on its correct position. Isn't the easiest thing to line up.
http://www.ebay.com.au/itm/1807...trksid=p3984.m1439.l2649
Have had major leaking issues since installing P/S nearly 2 years ago. Tried everything. Rebuilt the kit twice & changed the hoses twice. No change. Replaced the lid. No change. Nothing leaks when stationary, and none of the hoses/joints leak under revs at full lock
(was told this is sometimes an issue because of the pressure build up).
Have been informed recently about the pump-to-engine mount brace, which I didn't have installed
(and had actually never heard of or even seen before). Was told that without it, the pump actually shakes - worse the higher the speed - causing the fluid to come up & out through the lid.
This makes sense in my case. If I'm driving casually doing no more than 60kph everywhere, I'll only need to refill the reservoir twice a month. If I'm constantly doing high speeds, it's much worse. Last week back & forth on the F3 I had to fill it up 3 times. Wasn't just a top-up up either. Every 2 days it was dead empty - with fluid all over the drivers side of the engine bay.
Edited by user Tuesday, November 8, 2011 3:27:46 AM(UTC)
| Reason: Not specified
