HG80437 Offline
#1 Posted : Tuesday, November 8, 2011 6:50:39 PM(UTC)
HG80437
Hello All,
Still in process of restoring my HG Monaro, recently pulled lower control arms off crossmember for refurbishment, found pivot point on drivers side front to be badly worn. (No threaded surface left on top of pivot). Is ther any way of repairing?
I have another crossmember margainly better, also some wear on same pivot point.
When reassembling should some grease be applied to the threaded area the bush slips over to help prevent further wear?
Some searching has suggested HK crossmembers and control arms are not interchangable with HG? Anyone confirm?
Also on my spare crossmember the front brace has no holes in the side of brace, all others I've seen have holes in sides as well as top, what might this crossmember be out of?
Any advice much appreciated.
Thanks, Steve
dirty davo Offline
#2 Posted : Tuesday, November 8, 2011 7:51:50 PM(UTC)
dirty davo
Originally posted by HG80437
Hello All,
Thanks, Steve
OK, your talkin about th "K frame" or "front cross member"
the body of k frame is all th same, just different lower control arm pivot shaft from HK to HT/G (HK is smaller diam, with no thread im middle)
you could get a shaft out of another one (they screw out but can be hard to get moving)
the "outrigger" (sticks out front of K frame is solid sided on all later HG models"
hope that all makes sense
regards DD
HG80437 Offline
#3 Posted : Wednesday, November 9, 2011 10:34:30 PM(UTC)
HG80437
Thanks Dave, whats the best method of unscrewing pivot shaft, is it one piece thru the crossmember ( 2 pivots on one shaft- 2 shafts per crossmember ) or is 4 seperate shafts?
Is there many cars out there that have good shafts to source from? The ones I have seen are usually worn.
Is the idea of some grease on pivot before pressing in bushes a fair idea or would it lead to reduced life of the rubber bushes?
Steve
dirty davo Offline
#4 Posted : Thursday, November 10, 2011 12:16:58 AM(UTC)
dirty davo
Steve
yes, just one piece per side. heat up with oxy, or weld a big nut onto it & screw out thru front (usually take a fair bit to get moving!
th thread where bush fits is fairly blunt & i would have some good ones here with no wear on em
regards DD 0412109239
69 rust bucket Offline
#5 Posted : Friday, November 11, 2011 7:43:02 AM(UTC)
69 rust bucket
they unscrew looking from the rear of the k frame turn them clockwise as dave said a bit of heat.but you can put 2 nuts on the thread one acting as a lock nut but not easy.there is someone on ebay selling new ones but i think only hk type which may be different
why drink & drive when you can drift & slide
dirty davo Offline
#6 Posted : Friday, November 11, 2011 6:51:47 PM(UTC)
dirty davo
yes HK are different diameter.i have 2 NOS bottom shafts here for HK. one has holden tag, other is stamped 'dufor'
Sebring Orange Offline
#7 Posted : Friday, November 11, 2011 7:37:00 PM(UTC)
Sebring Orange
Dufor Made Suspension bits for Holden anyway, so you have 2 genuine ones there !
This page was generated in 0.100 seconds.
