                Hi guys  just a quiry about transbrakes and how they work???wats the price of these iteams??roughly
                They generally work by locking the trans in 1st & reverse at rhe same time (by modifying the fluid paths within the box), and when you release it, it merely drops revese back out of gear & it powers off in 1st.
  As far as cost goes, I ave no
                If you are talking about manual ones the Landrover has them and also the early Dodges/Chrysler products. I would imagine they are on other vehicles as well. They work by having a large brake band lined with brake lining stuff it wrapls around a drum on th
                Also the one in autos isn't that just a spur that jams the gears? Like putting a bar in the spokes of a bicycle and about as good at wrecking the transmission if you use it when moving at any speed.
                http://www.raceglides.com.au
 Ask these guys, they will probably recomend buying a trans thats built from scratch to suit a trans brake.
                They are no big deal just a drum on the back of the gearbox like a big pulley and a brake mechanism. I have a vague feeling some of the Landcruisers had them too.
                Nah your thinking of a different type, for race/drag applications its all in the valve body and controlled by a electric solenoid and button. They work like this: When the trans-brake is engaged, the vehicle can roll neither forward nor backward, and as y
                Some transbrake kit prices from B&M and TCI...
  Part No / Description
  TCI-121900 / Trans Brake Series Torqueflite 727 & 904 Pro Tree Trans-Brake Kit $1,427.95
    TCI-121901 / Trans Brake Series Torqueflite 727 & 904 COMP Trans
