#1 Posted : Monday, 14 June 2004 6:07:24 AM(UTC)
ok thanks to drterry for the other info, ok now putting the disc brake front end on my eh whats the best option for the master cylinder and booster? at the moment its a single outlet master cylinder with no booster
#2 Posted : Wednesday, 16 June 2004 1:29:15 AM(UTC)
depends on your set up. You can buy a new master cylinder to suit or recon your orginal. You will need to take the last piece out of the innards of the master cylinder (looks like a washer)You can mount a VH 40 on the inner guard in front of the horn or y
#3 Posted : Wednesday, 16 June 2004 7:12:48 AM(UTC)
hi thanks for that, much appreciated.
#4 Posted : Wednesday, 16 June 2004 8:13:09 PM(UTC)
I have a vh40 booster, mounting bracket and brake lines (but not master cylinder) for sale. Came out of an ej and was working fine. Very simple bolt in job
email [email protected]
You will need a disc brake master if you have discs
This page was generated in 0.145 seconds.
