#1 Posted : Wednesday, 16 June 2004 5:02:56 AM(UTC)
I have a t bar to put in my hz one tonner,I have the linkage that connects to the tbar under floor,Ive changed the lever on the trimatic,so how does the linkage connect to the lever on the trimatic,the lever has a hole in it and the linkage is just a bar at that end
#2 Posted : Wednesday, 16 June 2004 6:24:03 AM(UTC)
Hi Michael.
The main part you are missing is called the trunnion, in GMH language.
What you need to connect up are the trunnion, grommet, bolt & washer.
You may still be able to buy these from Holden, but if you can't, try the wrecke
#3 Posted : Wednesday, 16 June 2004 6:34:57 AM(UTC)
Ill send u an easy to veiw pic again, keep an eye on your mailbox tomorrow nite...
Cheers Kev
#4 Posted : Wednesday, 16 June 2004 6:35:43 AM(UTC)
Cheers Kev
#5 Posted : Wednesday, 16 June 2004 6:46:18 AM(UTC)
Just searched for trunnion in the Holden shop link above and found this - any help?
TRUNNION SHIFT ROD 2ND 3RD HQ - WB
Order Quantity: TRUNNION SHIFT ROD 2ND 3RD HQ - WB
