#1 Posted : Tuesday, 29 June 2004 9:38:03 AM(UTC)
I have a HX Ute with a 202 motor and a 4 speed Aussie box, the clutch cable goes from the pedal to the bracket which is bolted to the side of the bell housing. I would like to know which type of clutch is needed, Push or Pull?
Also are the 3 and 4 speed bell housing's the same and are the clutch forks the same? Bell housing is from a HT/G. Any comments appreciated. Thanks.
#2 Posted : Wednesday, 30 June 2004 3:01:27 AM(UTC)
If it's a genuine HX half rat trap you need a PUSH. The half rat-trap is a see-saw type mechanism which changes the cable PULL into a rod PUSH. The HK-HG bellhousing is basically the same (as long as it is off an all synchro 3-speed) as the HQ-HZ 3 and 4-
This page was generated in 0.111 seconds.
