#1 Posted : Thursday, July 8, 2004 5:14:30 AM(UTC)
Hi,I need to get rid of a recoed T-700 suits 5.0L. It is in the car for testing and has done 10klm. I am in the Brisbane area and I am chasing $1200. This is less then the cost tranny shops quote to recoe just the tranny, not sell a complete one.Cheers Lee
#2 Posted : Thursday, July 8, 2004 8:49:23 AM(UTC)
What model T700 is it ? I am after something to suit VT.
What state you in ?
#3 Posted : Thursday, July 8, 2004 8:58:06 AM(UTC)
I am sorry. I meant to put in that it is in a VN.
#4 Posted : Friday, July 9, 2004 12:03:10 AM(UTC)
Just out of curiousity, if anyone knows, will these bolt behind a red 308 (turbo pattern block). I run a T400 now, but if it was to die a 4 speed auto may be the ticket? If so are there any complicated wiring or other issues, eg tailshaft length etc?
#5 Posted : Friday, July 9, 2004 1:33:12 AM(UTC)
I am interested, where in Brisbane are you, and do you have any photos of it? Also who did the reco?
Jason
#6 Posted : Friday, July 9, 2004 4:30:12 AM(UTC)
As I know it you tailshaft needs to be shortened to accept the T700. This is'nt very expensive though.
Other than that, I think VN T700 should be fine wiring wise as its still mechanical from when I have been told. VR and up require wiring harnesses
#7 Posted : Friday, July 9, 2004 4:49:44 AM(UTC)
Sorry Hz Sandman, I think you will need an adapter plate, and you need to wire up the lock up converter otherwise the transmission will run hot and eventually fail. Also as u stated the tailshaft will need shortening.
#8 Posted : Friday, July 9, 2004 7:23:36 AM(UTC)
Hi Jason, No photos because the transmission is in the car so it can be test driven, as mentioned it has only done 10klms. Send me an E-Mail so I can give you more details and make further arrangments if you are interested. I did the tranny myself and can
