#1 Posted : Thursday, 19 August 2004 9:32:44 PM(UTC)
Hi guys.
I hvae a HK monaro with std 10 bolt diff and brakes. up front I have a new HQ disks, HX calipers.
No matter what I do I cant loose the spongy pedal. I have a new Master Cylinder, new braided brake lines.
What else do I look for?? It will stop pretty well. It is just the spongy pedal that I dont like.
What else is there for me to check and anything to look for??
#2 Posted : Thursday, 19 August 2004 9:49:34 PM(UTC)
Spongy brake pedal is usually associated with air in your brake lines.
HQ have a split fluid chamber front and rear. Make sure you have oodles of fluid, or if new and clean re-use it to top up, the master cycle as you bleed the lines.
Bleed
#3 Posted : Friday, 20 August 2004 6:25:47 AM(UTC)
Make sure that your rear brakes are adjusted up correctly. If the self adjusters are stuffed and the linings aren't adjusted up the pedal will be spongy.
Kev
