#1 Posted : Saturday, 4 September 2004 6:28:18 AM(UTC)
can anyone tell me how to wire a ht gts tacho on, the two attachments on the back are marked brown, which i assume goes to the positive on the coil, and the other marked pink, is this the positive? thanks
#2 Posted : Saturday, 4 September 2004 7:53:53 AM(UTC)
Hi Watto,
Pink wire under the dash of an old Holden is an ignition feed....so brown to coil, pink to an ignition feed (can be the same feed as for your other gauges) and an earth. To complete it properly, hook the feed for the globe(s) in your tacho
#3 Posted : Saturday, 4 September 2004 4:51:01 PM(UTC)
Hi Guys.
Pink = 12V ignition +ve (underdash fusebox)
Brown = Coil -ve (not +ve)
Grey = dash lights (underdash fusebox)
Don't forget case to earth.
#4 Posted : Saturday, 4 September 2004 6:03:01 PM(UTC)
thanks qute and the doc, i'll try that today gents, regards wato
