#1 Posted : Sunday, 27 June 2004 10:44:44 AM(UTC)
Hi all,
I want to replace a brass fitting on my inlet manifold (308 V8 red motor - it's the vacuum fitting on manifold for the brake booster) with a nylon fitting. Will this be OK? Will it resist the heat and engine bay environment? All replies appreciated.
Paul E
P.S. Reason for this is that the brass fitting is so close (2mm) to the dizzy cap (large HEI style) that you get sparking/arcing between the dizzy cap and the brass fitting (i.e earth). And yes, I have checked all leads etc for excess resistance and I am sure that it is due to me powerful custom CDI setup.
