YetAnotherForum.NET Help
#1 Posted : Friday, 15 October 2004 3:12:06 AM(UTC)
Can anyone recommend someone in the Brisbane area to make a long range fuel tank with an internal swirl pot for a HZ ute with EFI? Or is there a tank from another car that can be bolted in easily? Thanks in advance.
#2 Posted : Friday, 15 October 2004 8:14:09 AM(UTC)
I have been told and I do not know if it is correct or not because I have not looked into it yet but a 95 Rodeo fuel tank will bolt straight in and has the surge tank and pump ready to go. Check it out because I would be interested to know if this is corr
#3 Posted : Friday, 15 October 2004 5:45:31 PM(UTC)
Great idea! Only potential problem is what about the fuel sender unit, how would you go about making it work with a HZ fuel guage?
Cheers Dre
#4 Posted : Friday, 15 October 2004 6:45:37 PM(UTC)
Hi Matt,
Just in case you don't know, when doing the efi converion in utes & tonners you don't need the lift pump, as the tank is above the main pump, so the main pump will be gravity fed. You really only need the lift pump in sedans. I've only
