#1 Posted : Saturday, 23 October 2004 12:06:06 AM(UTC)
Hi guys,
Can anyone tell me where I can find a bracket to mount the powersteering pump to my HX 202 ute. It has the original red motor.
Also need to know which harmonic balancer/pully to use.
Any help is much appreciated.
#2 Posted : Saturday, 23 October 2004 4:09:18 AM(UTC)
Use a bracket off any 6 cyl HQ - HZ or VB Commodore. The brackets look very home-made but are factory original. I think, but am not 100% positive, that the Blue motor brackets out of VC/VH Commodores are the same. Just make sure you get ALL the bolts and
#3 Posted : Saturday, 23 October 2004 8:01:08 AM(UTC)
Hi,I can supply all you need. The two brackets, the pulley (a/c combo if needed),all the bolts,and all six spacers. $90.00. If you are interested e-mail me sharlees@tpg .com.au (ignore the space) Cheers Lee
#4 Posted : Monday, 25 October 2004 10:18:41 PM(UTC)
Best bet is to pull one of an early Commodore yourself, and as Qute says, get the bolts and spacers, especially the ones off the thermostat housing. HQ to HZ had a second bracket that attaches to the rear of the pump and bolts to the engine mount (also a
#5 Posted : Monday, 25 October 2004 11:28:48 PM(UTC)
Thanks guys for the help. I'll see how I go. Keep an eye out I may have more questions
#6 Posted : Monday, 25 October 2004 11:30:01 PM(UTC)
#7 Posted : Tuesday, 26 October 2004 3:45:54 AM(UTC)
Hi Byron.
All Commodore 6 cylinders with this pump set-up have the 2nd bracket.
It's just thast so many Commodores have been converted (by owners) & they are too lazy or just don't know about fitting it.
Dr Terry.
