2 Pages<12
tanart Offline
#21 Posted : Wednesday, 1 July 2009 11:55:36 PM(UTC)
tanart
Tour, the inner belts with the metal insert fitted perfectly. All other belts fitted good, except the rubbers that sandwich the rear windows. When you bolt up the plates that hold the rubber in place on the rear glass, the rubber gets squeezed upwards and there is a 3mm gap between the top of the plate and the rubber. I had to re-drill holes in the rubber to bring it down a little, so when the rubber got squeezed it would fit perfectly. When compares to the original the rare spares rubber holes lines up as the original. Maybe the type of rubber used is too flexible. Thanks Anyway. Are these new rubbers available in the HK_HG rubber Kits?
Tour Director Offline
#22 Posted : Thursday, 2 July 2009 2:38:30 AM(UTC)
Tour Director
Thanks for the feedback.The inner door belts met with your approval which is good to know, thanks for contributing your comments.The rear lower rubbers were test fitted here and approved by one of our regular fitters, but we will check them.The kits are usually revised when new products are added to the existing range.With all the new items coming through this is a continual process.
2 Pages<12
