Is there a book that can be used to decipher GM screws nuts and bolts , for instance nut " u spring type No8a" and screw " type 6 -18" x 1/2" . Is there some kind of reference from part number to description of the part. Example 133822 is a Flat head slotted bolt 5/16"-18 x 5/8" which I presume is 5/16" Dia x 18 TPI and 5/8" long. but type 6 or No 8 means nothing to me am I missing something Les
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
Some of the catalogues have Engineering drawings of each one. I'll have a look later.
I cannot find anything with a full break down but this is what is in my HJ parts book. that is a insert from this page http://i872.photobucket....ch/BoltsHJpartsbookL.jpgThere are 11 pages of bolts nuts screws etc If that is along the lines of what you are looking for I will copy them for you I you want them. Cheers Paul.
Paul Copies would be most appreciated, I have a HJ book but it does not have that section instead it refers to Standard Parts Catalogue PA1006
I have an old "GeeJay" kit marked "self tapping screws - suit Holden vehicles"...I'll have a squiz in it.
Hi Les. It is from the M37529 October 1974 HJ parts book. There seems to be a similar listing in the Master parts catalog up till HR as well Do you want a copy of that one too. Where do you want me to email these to as I will send large images to make it easier to read. Cheers Paul HQSS@oldholden dot com
Hi Les Email sent. James that was a quick post and removal of the post. What is the part number of the catalog that you posted the picture of. Cheers Paul.
