Hey there was wandering if anyone was able to tell me the ohms empty and full on a HZ fuel sender so i can change the gauge to after market and one that actually works
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
73 ohms - empty 25 ohms - half scale 10 ohms - full
It would be easier & possibly cheaper to have your current gauge repaired & re-calibrated by an instrument guy. It would also look better. Most aftermarket gauges nowadays are Taiwanese or Chinese cr@p, so be patriotic & fix the original Aussie part. It's already lasted 30 years, fix it & it will go another 30.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
I knew my Haynes service manual was wrong! From memory that said it was the other way around, which makes no sence as my fuel sender is reading open circuit and the guage is always at empty. There's no way to get at the sender without dropping the petrol tank is there?
No way to get it out comfortably ,I'd be checking the sender first thou.
Jim in Adelaide.. |
Jim in Adelaide.. |
thanks for your help guys
