Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
He advertised in ebay or gumtree stating that he makes the panels but like you I can't find the reference where I read it- doh!
Joined: 25/12/2015(UTC) Posts: 156 Location: melbourne
thanks ausjacko, I do remember seeing it on ebay, you have just reminded me.. if only I could remember when and were I had written his number down..
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
benny I reckon you wrote that number down and placed it in a spot you'll always remember where to find it only to find out, after tearing the place apart, that it's nowhere to be found. You'll probably find it in a couple of years time while looking for something else. happens around here all the time mate.
exactly kbm, with a bad memory like mine and all the junk I have around here from my holden hoarding disorder, might be a while, cheers..
Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Hello Benny.
Dean Prodger is highly capable and can make just about any HKTG panel. I know him and can recommend. Link:http://www.deanosautorestorations.com.au/
"HOLDEN MONARO. OUT TO DRIVE YOU WILD!" |
I spoke with dean yesterday, and he said he is too busy, thanks for your input, cheers..
You could contact David Smith from Bellarine Classic Autos. They posted on facebook a couple of days ago indicating they are having them remade from the original dies. Here are a some extracts from that discussion:
Update on the NEW HK Monaro quarters: eta Jan - Feb 18 HT and HG in the following months. Delays are beyond our control. These are being pressed out of the original factory press and will be worth the time and effort going into this process. Long story short, Holden sold them for scrap and the scrappy had the hindsight to put them into storage. Still not finalised however we are hoping to sell them for around the $5,500 price mark per panel.
Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
I’m still skeptical as GMH used a massive Hamilton press for those panels, and unless the same pressure can be applied (which I doubt) they can’t be the same off the original dies. We’ll see though I guess.
How’d they get the HK dies? They would have been modified into HT surely? As I said time will tell! |
Don't know the answer to that HK; just happened to see the discussion the other day. Not certain if this will work but here is a link to the discussion. Even if you are not a member of facebook I think you should be able to read the whole thing - you will need to expand all the comments on the subject by clicking on the line reading "View 18 more Comments" You will see comments to the effect though that the dies need restoration work to get the body lines correct - work which is underway apparently https://www.facebook.com/groups/dirtydavo/
Yep David Smith is the man to contact in regards to new Monaro quarters in the pipeline. |
1968 HK Ute 327 T350 Old Skool Cruiser |
