Thanks: 1 times Was thanked: 480 time(s) in 458 post(s)
Anyone game? It’ll fit as a 250 was standard fitment in South Africa, with TH350. Should use all HQ SBC stuff like radiator, box location, gearbox crossmember, tailshaft. https://www.gumtree.com....-292-big-six/1177348190
Joined: 2/02/2009(UTC) Posts: 562 Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 30 times Was thanked: 8 time(s) in 8 post(s)
Originally Posted by: HK1837 I've pondered that swap myself. As an example the 292 offered more Net HP & torque than the 283. I wonder what a worked one could put out. And in a dim light, pass it off as a 202! |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
