Joined: 3/06/2018(UTC) Posts: 1 Location: murray bridge
hi ive just purchase a hk premier can someone work out codes body number 80569403-a paint 58710073 trim 1164-14 T also under the main tag stamped in body is a number hk03324a can someone tell me what they mean thanking you
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
HI ariel. The numbers translate to an HK Premier sedan, the 403rd such unit built at the Elizabeth (Adelaide) plant. It was also the 3,324th HK (of all HKs) built that plant. It was finished in Paragon Blue metallic & trimmed in Light Teal Morrokide vinyl. Dr Terry Edited by user Sunday, 3 June 2018 6:34:21 PM(UTC)
| Reason: Not specified |
Just to expand a tiny bit on Dr Terry's info, it is the 403rd HK premier sedan body out of Elizabeth body plant, not the 403rd one actually assembled at Elizabeth. Elizabeth bodies were exported to Mosman Park for assembly as well, and a lot of their bodies were early ones. Nice car BTW. To be totally correct it won't actually be the 403rd Premier sedan body out of Elizabeth body plant, as some of the early Brougham bodies out of Elizabeth were tagged as Premier sedans as well so it'll be maybe the 400th or 401st or thereabouts. Edited by user Sunday, 3 June 2018 7:33:40 PM(UTC)
