Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi Holdeners A friend has an EK ute and has asked what the correct exhaust flange for it. Not knowing anything about this car or motor for that matter, thought I would 'ask a friend'. Any help appreciated. Cheers Jacko
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
standard flange for EK is part no.7401482. same for FE FC FB EK and EJ. hope that helps
1 user thanked KBM for this useful post.
Thanks. Any hints on who has them? RS does not seem to stock it.
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Ausjacko, are you after the flange or the flange gasket ?
If you're after the flange itself, see an an exhaust shop, or you might need to get one made, not that difficult.
If you're after the gasket, FX to HD are the same & its industry part no. is JE359. Any Repco or Burson store should be able to procure one quite easily.
Dr Terry |
Dr T He is after the gasket. Thanks for the reference, I will pass it on.
