Joined: 2/03/2005(UTC) Posts: 488 Thanks: 3 times Was thanked: 7 time(s) in 7 post(s)
Can a Bosch su12 coil be powder coated successfully ?? AL.
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
Originally Posted by: gmholdman Can a Bosch su12 coil be powder coated successfully ?? AL. It depends on the curing temperature of the powder. If it is too high the coil will suffer. What is wrong with normal engine enamel ? Dr Terry |
Joined: 16/04/2014(UTC) Posts: 768 Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Originally Posted by: Dr Terry Originally Posted by: gmholdman Can a Bosch su12 coil be powder coated successfully ?? AL. It depends on the curing temperature of the powder. If it is too high the coil will suffer. Typical Dulux, Interpon or Jotun power coating is cured at around 190-200C, which is well beyond the rating of the coil copper winding enamel. Not worth the risk for an arguably small appearance improvement.
Thanks all, I will go pressure pack. AL.
