I'm looking for a BW diff to suit my VK sedan , apparently the VL diff is the one to get I can get a LSD centre from a mate and I'll be needing gears about 4 to 1 as I have a 3800 high stall TH400 and VN headed 308 going in my VK Does anyone have a VL BW diff ? I'm in Perth thanks lads Gary308
Thanks: 1 times Was thanked: 197 time(s) in 180 post(s)
AFAIK the only VK to get the BW diff were 6-cyl models from around Feb 1985 onwards & they were a 25 spline centre & had a 3.23 ratio, with LSDs being quite rare. All VK V8 had the Holden large Salisbury.
In VL all models had the BW diff. The 6-cyl non-turbo had 25-spline with 3.45 gears. V8s had 28 splines with a 3.08 gears, the Turbo 6 had 28 splines with a 3.45 ratio. V8 & turbo were usually LSD.
Dr Terry |
