Joined: 2/02/2009(UTC) Posts: 562 Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 30 times Was thanked: 8 time(s) in 8 post(s)
Question: I gambled a whole 20 bucks on a HZ triple gauge- fuel/oil/temp.
Any tips on how to test them? Missing the temp gauge needle, will the one from the fuel one fit?
I only want to use the temp & oil ones in the Buick. |
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Joined: 21/04/2017(UTC) Posts: 293 Location: Tolmie Thanks: 2 times Was thanked: 24 time(s) in 24 post(s)
not sure on the temp gauge with no needle but the fuel and oil should have two connections on the back. one should say pink which is positive. connect to 12v and should stay "empty" earth to second connection and should go to "full"
