#1 Posted : Monday, 16 January 2006 1:44:58 AM(UTC)
I have fitted VZ front disc and calipers to the VS statesman and all is good , the rear fit (it has IRS) but the original handbrake shoes are about an inch away from the disc ( I have left the VS ones on the back for now)has anyone done this conversion and are there handbrake shoes that fit correctly with the bigger brakes ? do VT-VZ ones fit?
#2 Posted : Monday, 16 January 2006 6:42:03 AM(UTC)
This thread may be worth a look mate:
http://www.brockcommodor...n/showthread.php?t=2140
Doesn't solve the prob, but shows you a creative way of adapting them.
___________________________________________________________
#3 Posted : Monday, 16 January 2006 7:29:16 AM(UTC)
HMMM ..I might make some calls through the week and see if the VZ handbrake gear fits. Even as it is with the twin piston calipers up front and larger discs she stops sweet.
Anyone doing this front swap its easy , just remove the VR-VS dust sheild and bo
