hey y'all my vn is not firing on all cyl's. gone through the book,done all checks. new coil pack even (cause i stuffed up and broke one of the tabs clean off. Don't ask! ) crank sensor ok. tests to ignition module say it ok....why no spark on number 5 and 2?
Hi boots.
Could be the DFI module. That's the one under the coil packs.
Dr Terry |
thanks terry
thats whats got me stumped. like i said all tests say its ok.. but the book says "if no fault can be found change it out. just wanna be sure as it'll cost around 200 bucks.
