hello to you ...i was hopeing to find out some info on a hk munro i am looking to purchase..i would like to know as much as poss about the cars build history... the tags are ...HK80737-29772...80737K..J136604...firewall stamp..HK30095M... any info would be appriciated...thanks
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
It is a HK GTS built in Melbourne, but more info is needed to determine the car's originality as the 186S and 307 HK's share a commmon model code. What is the trim code?
Things to look for:
Speedo cable - does it go through the firewall in the centr |
thanks for the info....trim code.1150-10X...paint code..587-1704...regards smurf
