YetAnotherForum.NET Help
#1 Posted : Thursday, 2 March 2006 11:56:40 PM(UTC)
Hi Folks
I have a 1968 XT ford falcon (6 cylinder) with front and rear drums, and am wanting to upgrade to front disks with rear drums. Can I use the complete brake system out of an XF or XB model ford. Would I also be able to fit the master cylinder and booster between the firewall and driver shocker tower. Or would I need to mount the booster on the passenger side and the master cylinder on the drivers side like the XT GT's. Having said this is there anything I would need to do or pay attention to when making the transition to front disks.
Lastly if I were to simply stay with the original braking system, could I upgrade the drums to give a better performance, without having to channge the master cylinder.
your help appreciated
#2 Posted : Friday, 3 March 2006 9:38:34 AM(UTC)
you just have to love the xt falcon,im not realy sure but i think the xw xy discs are the go.as for the latter falcons im not sure as i have cortinas (have owned xw falcons etc).you wont get anything out of the drum front end so a disc front end is the go
#3 Posted : Tuesday, 7 March 2006 12:58:48 AM(UTC)
Hello John all is relatively simple here. You can update the front brakes by simply bolting on the stub axles off any XR-XG Falcon but there is one beware. If you use the front rotors off anything XC or later you will not be able to use your XT wheels as
#4 Posted : Tuesday, 21 March 2006 7:24:02 AM(UTC)
Hi,
I have a XT Wagon, have the entire front end from an xf, steering box, column, booster, master cyl, stubs, rotors, calipers etc etc, check my site in my sig if you want details on what to do.
www.madmagna.com
This page was generated in 0.110 seconds.
