I have got a VR with a 3800 which i use as my daily driver. Had this car for 12 mnths, with no problems and have put over 20k on the clock. Keep the car regulary serviced and recently replaced plugs, fuel filter, airfilter ect and ran bottle of injector cleaner through it.
This morning whilst sitting in traffic on the way to work it stalled on me, i managed to fire it back up after a few cranks, and it stalled again basically straight away. Cranked again and it fired, let it sit for a bit, gave it a few revs and it was fine. Drove another 20kms to work without a problem..
Any ideas? Is this the crank angle sensor stuffing up?
I
Sounds like it, start the car and leave it idling. Then shake the wire contacts going into the distributor and see if it stalls or changes rpm. Also stop the car and spray WD40 (or similar) on the contacts connecting to the distributor, this may solve the
Hi Guys.
The Holden V6 doesn't have a distributor.
The stalling problem, assuming the car drives OK in all other respects, is probably related to the throttle body or idle motor. The will need cleaning & resetting.
Unfortunatly you will need a sc |
Also check your fault codes. http://www.justcommodore...icles/vr_computer_v6.phphttp://www.techedge.com.aucrank sensor's can play up with heat and bad wiring but start with the codes and go from there. life's to short not to be....
drove it home from work, it did not stall once.. but surged a couple of times under load.
Cleaned throttle body.. as i was doing that i found a vaccum hose that ran from the throttle body to the vaccum cannister that was disconnected. Must have come off when i switched the battery on the weekend. Now seems good as gold.
