#1 Posted : Tuesday, 21 March 2006 4:54:10 AM(UTC)
Hi. Had to consult the internet today on how to get the idler mounting bracket off the idler arm which was very handy to find, but when I was putting it back together the idler mounting bracket when done up tight wasn't parallel with the chasis rail where it bolts onto to. So I backed it off (unwound) it until it was parallel and bolted it back on. Is this correct or very "Dodgy Brothers"? Any help would be greatly appreciated as I did not take notice when pulling it apart.D'OH
#2 Posted : Tuesday, 21 March 2006 12:05:03 PM(UTC)
Hi Tony,
I am no expert on HK -HG's but, on the HQ, you must leave the idler arm about 1½ turns (from memory) loose as the inner bit needs to be able to turn both ways when you move the steering. I assume the HK is similar. If you don't get any joy her
This page was generated in 0.136 seconds.
