Hello all, only just found this site wada ripa. I"ve got a HK I want2 restore 2 org. I need some help desyphering the numbers. firewall num. 15968A vin. plate body num.HK 80337-68-A, trim num.1101-14-X, paint num.585-10761. any help would be appreciated. thanks, GTS502
Is this car a Kingswood Coupe?
14X is the trim code for Medium Blue vinyl.
585- is a non metallic colour.
James
You only have to be in front at the end of the race. |
Do you have the VIN number? It's a HK Monaro (ie non-GTS), very early Elizabeth build. Teal blue vinyl trim (14X). Not sure what paint colour 1101 is, but early Monaros were built in pre-release colours and this could be Eden blue. Is it blue? |
Hi gts502.
Most this has been answered in bits, but I will put it all together.
15968A = Chassis number (I assume this has the letters HK in front of it) & A = Adelaide.
HK 80337-68-A = Body number , HK Monaro (non-GTS) & it is the 68th Monaro |
Thanks DR. Terry appreciate the info. mate.
