You are a member of these groups:: Guests
EMAIL ENQUIRY FROM NICK:
I am trying to source a set of hq style rotors for my hk but i need them drilled in hk patttern can you help thanks Nick
I believe that you can order them from DBA with the earlier stud pattern www.dba.com.au they should be able to tell you if they can do it or not otherwise you will have to take your rotors to a differential specialist that does conversions of 9" etc. Edited by user Friday, 26 May 2006 9:05:37 PM(UTC)
| Reason: Not specified |
I got mine from Hoppers. Would have no hessitation in recommending them. They did a perfect job. Just remember that the centre needs to be machined a bit too, this is so the HK wheel will fit. But they know all that, they told me about it. Go the slo
