Simmo Offline
#1 Posted : Monday, 12 June 2006 1:31:41 AM(UTC)
Simmo
Im building up a small block chev for a friends HT prem. We got a good deal on an aftermarket performance sump with oilpump and pickup. The pickup is long and has a tab to support it which requires an extended bolt instead of a standard bolt on one of the maincaps.
I assume all stock HKTG's would also have a long pickup to gather oil from the centre of the sump and possibly a long stud on one maincap. Ive always had extended bolts with a windage tray so dont know what is stock. Can I buy just one extended bolt for a 4 bolt mains?
#2 Posted : Monday, 12 June 2006 8:12:00 PM(UTC)
You should be able to as this is what the HT/G 350 manuals had. LH No3 part number 3960312 if still available. As it is a 39 part number it is a chev part not an Australian part, so probably used on some form of US GM vehicle.
Warren
