wimjack Offline
#1 Posted : Wednesday, 5 July 2006 10:31:32 PM(UTC)
wimjack
Hey Guys
I have picked up a 9inch diff housing and wanted to fit the disc brakes off a borgwarner diff onto it, Will they fit straight on or will I need different brackets etc?
Cheers Jack
#2 Posted : Wednesday, 5 July 2006 11:46:53 PM(UTC)
If you have an XF Borg Warner then you should have minimal problems. The axles will develop some end float due to the thicker "backing plate"
If it's an earlier borg warner then it's a job for a differential modification specialist
This page was generated in 0.016 seconds.
