witcheshollow racing team Offline
#1 Posted : Saturday, 8 July 2006 6:12:34 AM(UTC)
Are there any major differances between the V6's in the VN to VP to the VR? Can a V6 from a VR be droped into a VN and run using the same computer or the other way round? Any comments welcome here as I am trying to find out what if any differance there is between these 3 motors. Thanks all.
When the green flag drops the bulls@#t stops!!
"Such is life"
#2 Posted : Saturday, 8 July 2006 6:56:56 AM(UTC)
Basically the engine will physically bolt in.
Assuming you are putting a VR motor into a VN, you will need to basically:
* Use the VR cooling system parts.
* Use the VN engine wiring harness and extend the wires for the temp sensors if you have a 8
