Hi Guys,Glad to be a new member,Does any one know if there is a kit to leave the gear change on the column and fit a T400 to my beloved Q?It was Tri matic and of course the the 400 has the gear change linkage on the left.Cutting the floor is not an option.Thanks for any help,Doug.
Hi Doug.
There isn't a 'kit', as such, available, but since Holden did fit the TH400 with a column shift to many HQ/HJ/HX/HZ cars, then sourcing the required 2nd hand bits shouldn't be too hard.
Dr Terry. |
Thanks ,does any one have any for sale?Cheers Doug.
I may have a complete set-up. Will have to look through all my spares. Do you have an email addy I can use to contact you directly?
