Fastlane
Holden Forums
Holden General Discussion
weight difference between 1 tonner and ute
Does anyone know the weight difference between a hq 1 tonner and a hq ute?? thanks
Does the one tonner have a tray or no if so what kind of tray and what year is the ute,one tonner.
Heres the info from a simple search at the Holden forum site:
HZ one tonner with a 202 1655kgg minus 237kg for the alloy tray. HQ cab and chasis with a 173 and 3 speed 2818 pounds pay load 2240 pounds. HJ sandman 500kg carrying capacity CVW 1950kg un
The HZ 202 and HZ 173 tonners will weigh all but the same as they are basically the same thing, unless the HZ is an ambulance pack, and even then there will only be a mickey hair's difference. The 1950kg HJ XX7 (500kg carrying capacity) Sandman is 1950kg |
Fastlane
Holden Forums
