#1 Posted : Monday, 21 August 2006 5:25:00 AM(UTC)
Hi Guys,
I've finally got my hk on the road and have been using it daily for about 2 weeks now (which makes me very happy!) it's original 186+p.glide with a 3.36 banjo + i'm getting around 19mpg or 7kmL in varying traffic, highway, suburban + hilly, using 95 fuel + valve lube.
I know a major contributing factor to my fuel consumption (aside from needing a good tune) is the powerglide, which demands top gear at around 45/50kmh going up hill...yes it's painfully slow and very load-bearing on the engine as it's 14km to the top, but my only other option is first gear at a revvy 25km/h...basically the engine is strained in either gear.
Ultimately i'd like to fit a 5spd manual, but lack of funds means i'm more limited to something like a trimatic....so...am i going to need a ht/g crossmember, and will this even bolt up to my hk?
can i use the original column shifter? the p.glide gear change linkage is on the left, so which model trimatic should i use?
The p.glide uses a rod linked from the manifold for kickdown actuation, would this become redundant? can i use the correct vaccuum line from the trimatic and plumb it into my existing manifold?
Finally, anyone got a really cheap (complete AND reliable) 5spd setup for sale in south east qld ;)
PS i also just discovered the fuel tank is leaking, through a previous repair of what looks like 'metal mend'or something like it. should i try to reseal it or forget and fit another tank. i have a spare tank that doesn't leak but the floor mount support is a bit rusty in few places...
i'd rather hated for who i am than loved for who i am not.
Edited by user Monday, 21 August 2006 5:30:55 AM(UTC)  | Reason: Not specified
#2 Posted : Monday, 21 August 2006 8:38:13 AM(UTC)
I fitted a powerglide in my 149 EH it would run to about 75 mph so your not really overrevving at 25kmh(about 17mph).The Commodores had the gearshift on the left so might be compatible but you would run out of slots with the 2 speed. You should be able to
#3 Posted : Monday, 21 August 2006 11:41:44 AM(UTC)
thanks johnperth, not worried about not being able to select first gear if it's really not possible, i just hate being limited to 2 speeds gears. i'm thinking a trimatic would be my cheapest option...any ideas on the other parts (ie crossmember) fitting?
#4 Posted : Monday, 21 August 2006 7:28:25 PM(UTC)
Was thanked: 608 time(s) in 575 post(s)
Your best bet is probably going and finding an original 6cyl auto late HT or any 6cyl auto HG and getting the column and trimatic shift linkages off it and use these with a HQ-WB driver's side shift trimatic gearbox. You might have a bit of buggering arou
#5 Posted : Monday, 21 August 2006 11:37:21 PM(UTC)
Hi Guys.
If the car is currently an HK 6 cyl Powerglide, then the existing crossmember, tailshaft & manifold vacuumn fitting can all be re-used.
The only fiddles will be kickdown & shift linkage. The existing column can be used, you just won't have
#6 Posted : Tuesday, 22 August 2006 2:27:06 AM(UTC)
Originally posted by Dr Terry
The existing column can be used, you just won't have 1st & 2nd selection.
#7 Posted : Tuesday, 22 August 2006 5:01:27 AM(UTC)
You wouldn't lose it - the box will still select it automatically and most likely it will still select by the column, but there will be no indicator for it - that is why I suggested the trimatic column. The bit about 'mucking around' was because IIRC the
Edited by user Tuesday, 22 August 2006 5:03:01 PM(UTC)  | Reason: Not specified
#8 Posted : Tuesday, 22 August 2006 5:07:53 PM(UTC)
Hi Guys.
Yes, I did word that badly. The automatic will still go 1-2-3 when drive is selected & you will be able to select 2nd manually, but you will need to alter the length one of the selector levers to make sure the column lever has enough swing to
#9 Posted : Tuesday, 22 August 2006 10:52:01 PM(UTC)
Hey guys,
On the HG auto's isnt there a collar on the end of the steering column (in the engine bay) that acts like a gate to select the P, R & 1-2-3 (otherwise the rest of the set-up in the column is floppy)? I assume with the HK's powerglide this would
#10 Posted : Wednesday, 23 August 2006 12:24:55 AM(UTC)
I also worded the bit about the kickdown badly. I meant the electric kickdown on the trimatic is not absolutely necessary (although advisable to fit). I used to run a VK 6cyl trimatic in a WB tonner without an electric kickdown. Also a TH400 in an MQ patr
This page was generated in 0.145 seconds.
