2 Pages<12
sly376 Offline
#21 Posted : Wednesday, 20 September 2006 4:23:42 AM(UTC)
sly376
Yeah ran the cam in after start up held the revs up for about 2000rpm for about 15 min, The cam bearings look a slightly different shade on the bottom of them to the rest of the diameter, I had another look today & they don't look that bad, one of the lif
XB351 Offline
#22 Posted : Thursday, 21 September 2006 2:08:16 AM(UTC)
XB351
if you have double valve springs? Don't run the inners during run in. Swap them in after 20 mins. When fitting new lifters make sure they all fall under their own weight. If they don't? You'll kill a cam/lifters again. To get them to fall under their own
sly376 Offline
#23 Posted : Saturday, 23 September 2006 8:34:52 PM(UTC)
sly376
Cool thanks for that. does anyone want to sell a good set of heads that make good power? I need a set of good 2v's with 4v valves closed chamber, ported, screw in studs guide plates etc to run solids. What's a good cam to run now days? I want it to have g
XB351 Offline
#24 Posted : Saturday, 23 September 2006 9:11:12 PM(UTC)
XB351
Crane F238 solid.
#25 Posted : Sunday, 24 September 2006 12:07:12 AM(UTC)
i had a friend with a similar prob and couldn't work it out when we pulled the engine down we found the only thing wrong was a crack in the cam tunnel. i dont know how this could relate 2 the pinging but with all the same parts and a new block the problem
sly376 Offline
#26 Posted : Monday, 25 September 2006 2:59:45 AM(UTC)
sly376
What kind of HP can you get with a F238 solid? know any good mach9ine shops? I want to do a bit of porting etc. I want around 450hp at the flywheel if it's achievable.
XB351 Offline
#27 Posted : Tuesday, 26 September 2006 3:41:23 AM(UTC)
XB351
450 or close to is achievable with an F238. A mates running 350rwhp with an F238. Local to me? WOG engineering in Dandenong. It's opposite Betta Springs. I also highly recommend Pavtek in Lalor.
Brenden
Edited by user Tuesday, 26 September 2006 3:42:01 AM(UTC)  | Reason: Not specified
2 Pages<12
