#1 Posted : Friday, 13 October 2006 3:45:13 AM(UTC)
G'day, I'm in the process of trying to bolt my turbo pattern 308 to the M21 gearbox in my HZ. I know it's a simple matter of changing the bellhousing, however I have the cable clutch and the only couple of bellhousings I've found use the mechanical system.
What I want to know is whether it's possible to cut off the bracket that the cable goes through and weld it onto the new bellhousing? Or is there more to it than that? Failing that, does anyone have the bellhousing I need?
Scott
classic oz wreck Offline
#2 Posted : Friday, 13 October 2006 5:22:29 AM(UTC)
classic oz wreck
scott,no that wont work as the pivot for full cable is on the opposite side to the mechanical..like i tried to explain to you on the phone today,you either drill and tap the housing i have and buy the dellows full cable bolt on adaptor or change your clut
www.classicozwreck.com.au
