Hi All, can anyone tell me if the rear wheel arches of the HQ-WB commercials are the same as HQ-HZ Statesmans? I know they're definitely different to WB Rear wheel arches. Just chasing some chrome trims and want to make sure they're going to fit. I assume all the front wheel arches are identical on all models of HQ-WB.
thank you! Rhys
No. HQ front wheel arch moulds are definitely different to HJ-HZ. The rears are the same though. I do remember someone telling me that wagon/van/ute were different to sedan but I remember not believing them at the time, but I also believed in the tooth fa |
The rear arch on all HQs, Statesman HQ-Z, and Commercials HQ -WB are all the same. HJ onwards Sedan and Wagon are different (incl WB Statesman). I'm fairly sure the front Wheel arch doesn't change, my HX and HQ are the same, our WB is away being painted
hq fronts are definately different to hj x z front and wb statesman stands also by itself....hq wagon and hq hj hx hz and wb commercial rear are the same...hj hx hz sedan and wagon and statesman rear are different...very minor curve differences which are Edited by user Saturday, 11 November 2006 8:58:00 AM(UTC)
| Reason: Not specified |
According to the parts catalogue part numbers are:
HQ rear, 35, 37, 69, 70 and 80 body styles, LH 2815653, RH 2815653. HQ front, LH 2815133, RH 2815132.
HJ rear 37, 70, 80 and Statesman 69 as the same as HQ. HJ rear 35 and 69 (not statesman) LH 99 |
Thanks Byron, Anthony and Greg. It helps having part numbers to use as a reference hey Byron, I really appreciate you looking them up. Looks like the safest bet is to get a set from a HJ-HZ Caprice. (or a de Ville if it has them fitted) cheers Rhys
